new valve covers
Old Dec 18, 2004 | 01:55 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
new valve covers
How hard is it to replace my current valve covers, is there clearence issues? hiddin bolts? bolts impossible to reach? ect. ive never switched valve covers so any help would be aprecitated.
Old Dec 18, 2004 | 05:38 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
the passenger's side is a pain, for me anyways I have larger rockerarms:lala:
Old Dec 18, 2004 | 08:07 PM
Rockin-Iroc's Avatar
Car: 1986 IROC-Z
Engine: 355 ci TPI, 10:1 cr, Isky cam, ported heads, dual exhaust
Transmission: 700R4, ratchetting shifter, 3.23 rear
If it's a tuned port motor, the stupid hoses and wires are in your way, but remove the hoses and work around the wires. Be careful not to accidentally get a ground wire in the back of the head between the head and the valve cover. The leaking oil stench will tell you something like that happened. What I do is feel around the rim with my fingertips to make sure no wires got caught in there before tightening down.
MAKE SURE to disconnect your battery first!!!!!!!!!!!!!!!!!!!!
Look where your alternator is, as soon as you touch the wrong terminal, massive sparks everywhere!
Old Dec 18, 2004 | 08:58 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I second !!!
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
