? on the 10.4mm taylor wires
Old Dec 20, 2004 | 07:25 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys i was wondering if i will benifit any improvement by using the taylor 10.4 mm wires?im currently running accle 8 mm wires.
Old Dec 20, 2004 | 07:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will see no improvement at all. Stockers usually suffice. Aftermakret ones are good when you need every bit of spark with an ignition box, timing module, or are running boost/spray. I only went with a set of MSD wires because the stockers had to much radio interferance.
Old Dec 22, 2004 | 12:06 PM
Rockin-Iroc's Avatar
Car: 1986 IROC-Z
Engine: 355 ci TPI, 10:1 cr, Isky cam, ported heads, dual exhaust
Transmission: 700R4, ratchetting shifter, 3.23 rear
But any improvement is better than none.
Old Dec 22, 2004 | 01:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The gains per money spent doesn't exactly justify it, at least, not to me.
Old Dec 22, 2004 | 01:30 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
A good brand of 8mm wires works alright on a street driven car. Why pay for something you don't need or do you just brag alot about what you have. I wouldn't be impressed if you told me "I am using these 10.4 mm Taylor wires, what do you use??".
Old Dec 23, 2004 | 12:13 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
I's be impressed if you were running those 10mm wires.
I'd be impresed that you could find ANY wire looms or wire holders that will work with them.
I'd be inpressed that you went to all that trouble for absolutely nothing.
The only thing a sparkplug wire can do is allow the electrons to run through it and jump the spark plug gap without any 'leaking' off to close proximity metal objects.
8mm wires do all that magnificantly.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
