What Causes Grey Smoke?
Old Jun 10, 2001 | 01:05 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I was close to WOT, and I was told that I had grey smoke coming from my exhuast, what causes this?
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
Old Jun 11, 2001 | 06:14 PM
Vader's Avatar
Sounds like you are running just a little on the rich side...
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 12, 2001 | 08:06 AM
Car: 99 Formula
Axle/Gears: 342
Thanks Vader, just recently I have come to realize this and am trying to fix it. The only thing I have been fooling with right now is the idle mixture trying to lean it out. But I was told to buy new rods and jets to go leaner, but I just bought a reman. Edelbrock carburetor, shouldn't it already be right where I need it, I mean why would they make it run richer than normal. Also I have a 160* stat which I know isn't helping, but my car runs about 170-180. Is there anything else I can check or change to go leaner. My emissions test on the idle tests definately indicates a rich scenario, my readings were thru the roof.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
Old Jun 13, 2001 | 09:50 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
After making sure all carb vacuum lines are good and where they are supposed to be you might check for a code 15 bad CTS.
If your CTS was bad and your engine thought it was cold all the time your fuel mixture would constantly be enriched. 10 bucks.
Old Jun 13, 2001 | 09:56 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
A puff of black/grey smoke isn't necessarily a bad thing when you nail it, i'd rather have a rich transition than lean (and in fact that is how my 85 was set-up)
But if you're blowing agrey haze at WOT you are definitely way fat and wil gain a lot by leaning everything out. There is no reason to think an out of the box edelbrock carb should be dialed in from jumpstreet. Unfortuneatly i don't know much about the carter/edel. carbs so i can't really help you there.
Old Jun 13, 2001 | 01:36 PM
purpleworm's Avatar
When I did my quadrajet I just leaned the motor out till it started running rough and then I turned the screw back a bit so it would smooth out. I found this is the easiest way to do things. My car ran like a champ!
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
Autometer shiftlight tach and B&M mega shifter
One sweet sounding system
FormulasOnly
Jul 23, 2018 08:47 AM
gixxer92
May 18, 2017 11:20 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
tcarlos13
Sep 28, 2015 06:31 PM
