Replaced pick up coil....need help timing motor
Old Dec 22, 2004 | 01:29 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
Hey guys,
Well I was having a problem with my camaro... it was cranking but not starting....after replacing a few parts and posting a few times with no correct answer i was able to research it on here and find out that the pick up coil was the problem...so I went ahead a replaced the pick up coil. I had printed some directions that I found on a previous post and followed them as best i could...well after getting the new pick up coil in..and re-installing the distributor using the marks i made for alignment...the car starts...sometimes..but runs real rough......and wont stay running for more then a bout 20 seconds....i know i probably messed up the timing by not inserting the distributor in correctly. I checked all the wires..(i labeled them as i took them off so i know they are in the right spots...)
bascially what i need to know is... how do i time the motor or fix this problem now that the car has been cranked with the distributor in wrong....
ive never done timing on a car..so any detailed help would be appreciated...
Im pretty sure i have access to a timing light...
thanks in advance
Old Dec 22, 2004 | 01:45 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
you need to get no.1 piston tdc. remove plug rotate engin put your finger over hole and feel for pressure or if you can look in hole with light to see if piston is up. then check if timing mark on pully is at zero. pull dist cap and see where rotor is pointing. rotate distributer till rotor points at no.1 plug. then set timing.
Old Dec 22, 2004 | 01:48 PM
Axle/Gears: 3:08
and how to i rotate the engine... do you mean using the key and cranking it....im mechanically inclined..just not too familiar with this aspect of car repair....sorry
Old Dec 22, 2004 | 02:00 PM
SPIKE's Avatar
Car: 86 CAMARO
sorry, you can rotate the engin with the key but first disconnect coil wire so engin doesnt start. if your by yourself use a socket on the main pully center bolt should be 5/8 and rotate it. bit of a pain but you can also check no.1 piston while infront. quick tip! check timing mark on pully when set on zero. look at rotor it should be at either plug no.1 or no.6 if its only off a little you can adjust it from there. one rotation of timing mark at zero puts firing at no.1 then one more rotation puts it at n0.6.
Old Dec 22, 2004 | 02:01 PM
Axle/Gears: 3:08
thanks..sounds relatively easy....ill be checking this out tomorrow..ill post back with either results or new questions...
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
camaro71633
Sep 1, 2015 10:24 AM
Leggman1
Aug 6, 2015 04:15 AM
NBrehm
Aug 5, 2015 07:57 PM
