found a good deal on valve springs!!
Old Jun 14, 2001 | 08:20 PM
JJ's Avatar
JJ
NOT. I plan on putting some 1.6 rr's on soon and figured I would stick pick up a set of stock springs since they should be cheap. Stock L98 springs $8.00 each at the local GM dealer. To make it tech, what would anyone recommend as a stock replacement spring ? I'll probably order the springs gm performance sells that accommodate .500" lift, I had them on another car and they worked out fine. My last set was $30.00 from Pace, Hmm, $30.00 for upgrade or $120.00 for stock ??
Old Jun 14, 2001 | 08:55 PM
Guest
Guest
Posts: n/a
Call comp cams or summit racing, get some comp cams springs.
1988iroc350tpi
Aug 14, 2015 07:52 PM
ChevyZ71
Aug 13, 2015 07:30 AM
bjpotter
Aug 12, 2015 06:06 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
antares57
Aug 6, 2015 07:47 AM
