Keep timing at 0* on stock L03 or bump it up?
Old Jun 13, 2001 | 01:26 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Its a 92 RS T-5 Bone Stock.
Old Jun 13, 2001 | 03:02 PM
JPrevost's Avatar
Car: 91 Red Sled
Bump it to like 4, 6 or 8 if you aren't worried about knock. If it's BONE stock then run 6-8 shouldn't be a problem unless the EGR isn't working. Then you will have knock for sure (ecm advance timing thinking it has EGR on). If you go anything more than 6 I would run higher octane gas just because you're already running with 9.5:1 and it's better to be safe than sorry.
, Jon (350 TBI!)
91 Red My website
Old Jun 13, 2001 | 05:17 PM
Ragin'87's Avatar
i'm running a relatively stock L03 w/ 6* advanced base timing.. it's got a K&N and an "exhaust shop special" Flowmaster exhaust(i didn't put it on, but she's staying stock till then end of college.), and I run 87 octane. It gets slightly better mileage and seems to run a little better with 89, so I may start putting in 89.. or not.
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 76k miles.
Old Jun 13, 2001 | 05:52 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
higher octane gas shouldn't affect gas mileage, it burns the same as regular fuel..
only benefit you might get is that your computer sees it can advance timing a bit more and lean off the mixture..
check your fuel mileage by the amount of gas in your tank, don't go by your gauge..
i would runa tank of 87, run a tank of 89, and then decide if the mpg gain is worth the difference in price oyu paid to fill up..
Webmaster: www.IROC-Z.org
Old Jun 14, 2001 | 01:08 AM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
i run 93 octane in my 89rs and i get around 40-45 miles a tank more than 89. its worth it to me.
Old Jun 14, 2001 | 12:37 PM
Engine: 305TPI
is it worth the extra 4-6 dollars? that equates to about 3 dollars a gallon, ouch
Old Jun 14, 2001 | 01:44 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
<font face="Verdana, Arial" size="2">Originally posted by ColinOpseth:
</font>
Actually, higher octane gas burns slower than lower octane gas, but it won't make much of a difference in gas mileage.
Old Jun 14, 2001 | 02:38 PM
Engine: 305TPI
true..
what i was referring to was that the drivability is the same...
you only need higher octane if you have more compression, heh
Old Jun 14, 2001 | 02:44 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you are getting better gas mileage w/ higher octane fuel, that means one thing...you are running too much timing and the computer is retarding it to compensate on the low octane fuel.
Old Jun 14, 2001 | 11:01 PM
bubbz89's Avatar
Car: 1990 RS
well gas here is around 1.60 for 93 1.50 for 89 and 1.40 for 87. so for 10 cents more a gallon that 89 (87 not an option) it cost about 1.60 more for 40-45 extra miles a tank. its worth it to me.btw my timing is advanced 4*.
Old Jun 14, 2001 | 11:05 PM
bubbz89's Avatar
Car: 1990 RS
oh btw thats highway driving at an average of 65mph.
Jake_92RS
Jan 28, 2020 10:37 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
Thirim
Aug 9, 2015 06:19 PM
86Base
Aug 8, 2015 01:34 PM
