map sensor
Old Dec 31, 2004 | 08:01 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
map sensor
would low vacuum at the map sensor possibly be from a vacuum leak, i checked the line running to the sensor and its perfect. and i can't barly listen for a vacuum leak cuzz my motor barly runs long enough to check
Old Jan 1, 2005 | 01:16 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
A large vacuum leak near the tbi would basically be like opening up the throttle, itll idle real high. Nearer to a runner seems to just knock out a cylinder. Ive left the brake booster line off by accident and the car would still run, just with a dead #8 cylinder.
The high map readings do indicate a problem with either the map sensor, or more likely, an issue that effects vacuum. The egr would be worthwhile checking out. If its somehow stuck open itll cause a really lousy idle. There are lots of other things that can cause the motor to pull low vacuum as well.
The high map readings are more likely indicative of a larger overall problem rather then a vacuum leak.
Old Jan 1, 2005 | 11:10 AM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
so where would you say i should start at, besides the egr
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
