More Info for Help!!!
Old Jun 15, 2001 | 03:27 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Well here is some more info if anybody can help. When you speed up slowly the car will have little power and no POP. If I hit the gas then there is one loud POP and still no power. I have info on maybe a lean condition.....ANYBODY?
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
Old Jun 15, 2001 | 08:09 PM
btt
1989 Camaro RS
Old Jun 15, 2001 | 11:18 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Well, sounds kinda like what mines doing, the pop on mine is detonation, (aka spark knock/ping/etc) Mine does it only when it;s cold, after getting hot I can floor it with just the hesitation. I either have a small gasket leak allowing unmeasured air in, or what I think the problem is is a plugged fuel filter. By how you described it I am not sure if they are the same. Mine does come up lean, and sometimes the car will stumble and nearly die, actually setting the lean O2 code.
It really can't hurt to change the fuel filter, the new one I bought says to change every 10,000 miles.
Good luck
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
1987 Pontiac Trans AM (GTA?) 350 or is it a 305?! TPI
SLP 1 3/4" headers, 3" cat back (stock cat
MSD ignition.
MSD Blaster SS coil.
3.73 Rear end gears
Accell 8.8 Wires
Bosh +4 Spark Plugs (Don't know if they really help but hell!)
Holley AFPR
Race Built Automatic trans ('vette servo, shift kit, tightly packed clutches)--just needs titanium gears now!
Newly gutted cat (the car gutted it's own cat!)
Hypertech Chip (Just found out I had it! :eek
More soon when funds are avail...
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
