weird starting problem
Old Jan 2, 2005 | 08:15 PM
jay350ws6's Avatar
Car: 88 formula 350
Engine: 350tpi
Hey guys,i am new to this board but i am impressed,alot of you guys kmow your****.I am glad to be a part of it. I have question about a slight problem i am having,I just bought a 88 formula 350 it is in almost mint condition,it has slp headers,and exhaust and a few other things and i am pretty happy with it except for when it is cold out it starts a little harder and sometimes it will die but as soon as i turn it over again it is ok,it only does it when it is cold.When its warm no problem.The car has a accel ignition i dont know if this is the problem,because if i floor itit will studder from 700 rpm till about 1200 rpm but if i part throttle it no problem,other than thatthe car runs awsome and just plain flies! thanks for your help in advance
Old Jan 2, 2005 | 11:32 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: weird starting problem
Originally posted by jay350ws6
... i dont know if this is the problem,because if i floor itit will studder from 700 rpm till about 1200 rpm but if i part throttle it no problem,other than thatthe car runs awsome and just plain flies! thanks for your help in advance
All the time or only when cold?
As for the 'cold' problem, it could be your ninth injector is clogged or stuck closed. Is it worse during colder weather?
Old Jan 2, 2005 | 11:42 PM
jay350ws6's Avatar
Car: 88 formula 350
Engine: 350tpi
It only will die when it is cold but it firesright back up and is ok,but that little stumble is there all the time,the car has only 82000 miles on it and sat the majority of its life,i just wont it to run mint.thanks for the reply,if you have any ideas let me know
Old Jan 2, 2005 | 11:45 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
State of tune? Codes? I'd get that up to snuff prior to trying to troubleshoot. It always makes everything easier.
Old Jan 3, 2005 | 11:48 AM
jay350ws6's Avatar
Car: 88 formula 350
Engine: 350tpi
Thanks for your reply,I will have it all checked out.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
sreZ28
Aug 14, 2015 07:48 PM
92camaroJoe
Aug 13, 2015 06:07 AM
