Found one last connection I can't get.....help please
Old Jun 14, 2001 | 09:44 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
There is a connection that goes into the firewall in back of the driver side valve cover that I can't figure out how to remove. After I get this one out I just have to remove the ECM connection and the whole harness is out. Unfortunately I'm supposed to pull the motor and trans saturday morning and it's supposed to rain!!!
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Jun 15, 2001 | 03:42 PM
Car: 89 IROC-Z
Engine: 383
BTT.....Come on somebody has to know this one.
Old Jun 15, 2001 | 04:36 PM
MATEOZ28's Avatar
I just leave that part, thats the fuse block harness I believe. It should disconnect from the rest of the wiring harness with a few clips.
Old Jun 16, 2001 | 05:34 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Are u talking about the ground wires behind the head? If so u can remove the trans mount hold down bolt (single bolt under trans mounting pad) put your jack with a piece of wood on it, under the trans & jack it up. That should be enough to gain clearance to the bolts behind the head
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
eightsixseven
Dec 16, 2024 01:50 PM
Cornholio7979
Sep 20, 2018 02:31 AM
bjpotter
Aug 12, 2015 06:06 PM
marcusaw
Aug 10, 2015 08:13 AM
antares57
Aug 6, 2015 07:47 AM
