10.5 piston for 383
Old Jan 3, 2005 | 07:41 PM
lbrohez's Avatar
From: Decatur,, IL USA Search Posts:NONE.............. Whore Posts: All.................
10.5 piston for 383
I need a 10.5:1 piston for my 383 that i can have fly cut to clear my valves. any help is appreciated, because the pistons i have now are not going to clear my large 2.08 valve with my lift being .583 and 5.92
THanks in advance
Old Jan 3, 2005 | 07:45 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
srp has many with large valve reliefs
Old Jan 3, 2005 | 07:50 PM
lbrohez's Avatar
do you have a suggestion as to what piston to use, that is a really good brand, and do you know if it is thick enough to flycut?
Old Jan 3, 2005 | 07:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It might clear, and it might not. It depends on what the valve lift is at a point far away from peak lift (i.e. the .582" and all that, doesn't matter).
The only way to know, is to put a piston on a rod, assemble it to the crank, put the cam in with the timing set on like you intend to run it, put a head on with some sort of realistic head gasket simulation, and measure it.
I know you're getting tired of me telling you that..... but belive me, it's the only way you'll know.
I can tell you, that with that little bit of lift, you shouldn't have a problem, especially not if it's a roller cam; because the duration is going to be so short (like less than 250°) that the valves will be pretty much entirely closed the whole time that the piston is anywhere near TDC. If you're really really worried about it, and you've already got a set of pistons that your bore is honed to, have the valve reliefs for the intakes cut about .050" bigger in circumference.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
LT1Formula
Oct 8, 2015 08:34 PM
