Torque specs
Old Jan 3, 2005 | 09:16 PM
1986camarojoe's Avatar
Car: Z28
Engine: 310
Torque specs
Just got done pulling the TBI 305 out of my '91 camaro. Changing the head gaskets, rear main seal, and oil pan gasket. I need the torque specs for the heads, intake, harmonic balancer and the flywheel. (btw its an automatic i just forgot what that gear is called so I called it a flywheel.) Thanks
Old Jan 3, 2005 | 09:33 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
chilton manuels have all the torque specs, if i had mine i would look them up for you
Old Jan 3, 2005 | 10:13 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
http://www.darklair.com/monte/torque_specs.html
An auto trans uses a flexplate.
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
