'89 TPI Unit
Old Jun 16, 2001 | 06:37 PM
CamaroRS's Avatar
'89 TPI Unit
Monday I am going to go remove an 89 tpi unit from a wrecked IROC. I was wondering what tools I will need to bring along with me so I don't have any surprises when I am removing it. Also, what other tpi parts will I need to remove from the car to make the swap from tbi to tpi besides the intank fuel pump, ecm, wiring harness, intake manifold, plenum, runners, injectors and throttle cable. Will I need to get the wiring harness that is in the dash as well so that my gauges will work? Any suggestions would greatly be appreciated. Thanks in advance.
Old Jun 16, 2001 | 09:51 PM
snakeskinner's Avatar
well, I'd take as many tools as you can. Basic tools should get you there really. If you are wanting to disassemble the intake runners and such in the car, make sure and bring a full assortment of torx. all the runner bolts are torx (I believe T30 but it's been a while), the distributor cover is a T20 I believe and the intake itself are T40 I think. the runners have 5 bolts to the intake from the outer side and one from the backside. then they have 4 to the plenum that you can easily see. If the guages are the same as in your car, there should be no difference in how they operate but the sensors could be in a different spot so you may have to extend or loop wires. I would get every relay you can get your hands on while you're there. If you are taking your car to the location, you can use it as a model and see what's different and grab it. I would get ahold of camera and shoot as many photos of stuff as you can. This way you don't have a handful of parts in a week wondering where they came from. I have never performed this swap myself so I don't know exactly what is required but I'm sure there are many people on here that can help. Try reposting with a "Help with TBI to TPI swap" to get the people in here to read what you want becuase your topic doesn't draw the people you are needing.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
Old Jun 17, 2001 | 03:46 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
http://www.leannrimes.cz28.com
I have a small list of items that I needed for my carb to TPI swap.
You'll need some of the things I did.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Jun 17, 2001 | 07:08 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Take a full assortment of metric wrenches and sockets. Especially 14, 15 and 16mm sizes. Don't forget the computer
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Apr 14, 2016 08:52 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
Sanjay
Aug 12, 2015 03:41 PM
