Got a Code 34
Old Jan 4, 2005 | 08:05 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Got a Code 34
Well I just installed an Edlebrock RPM Q-jet manifold and I got a code 34 on the test drive. Haynes book says Vacuum Sensor Circuit. It says the possibilities could be wiring/connections at the ecm or the vacuum sensor. I doubt its has anything to do with the ecm so it must be the vacuum sensor. Where can I find the vacuum sensor? I have an 83 Z-28 with the carb'd lg4. I no longer have a egr valve with the new manifold, the line that went to the egr valve is plugged if that has anything to do with it. What do you guys think?
Old Jan 4, 2005 | 10:27 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Mike,
Your vaccuum sensor is located on the firewall near the drivers side. Check your e-mail.
Old Jan 5, 2005 | 09:21 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Got it, thank you Will it hurt my car if I drive around with the code? My car will pretty much be down for the week except when I have to drop off/pick up my bro. Hopefully I will get it corrected today.
Old Jan 5, 2005 | 07:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It shouldn't hurt it!!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
