4 qustions, (Short & Sweet)
Old Jan 5, 2005 | 11:02 PM
NEEDforSPEED's Avatar
4 qustion
1) what rods can i use in a 305 stoker? ( 335 )
2) can i use 6" rods on a stock 305 engine or would the pistons hit the vales?
3) do olds 307 rods fit a chevy cranks and wrist pins?
4) how much more comp whould you see with .20 over, bore on a engine with with 9 to 1?
Old Jan 5, 2005 | 11:24 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
1.) Use either 5.7 or 6" rods. Just be sure to use the correct piston.
2.) See above.
3.) Not certain.
4.) If you mean .020" overbore, nothing worth noting.
Old Jan 5, 2005 | 11:26 PM
what do you mean by correct piston?
Old Jan 5, 2005 | 11:29 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I doubt that there's an off the shelf piston available for a 335 with 6" rods.
There are pistons for the 5.7" rod however.
There are also pistons available for the 6" rod 3.48" stroke (305) I'll bet they have a lot of dust on them though.
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
