lg4 and l98 questions
Old Jun 17, 2001 | 04:00 PM
B84305-Streetmachine's Avatar
i have a lg4 in my berlinetta....yay.the motor sucks.....it knocks at certain throttle positions....u think if i took the l98 heads off of my parts car..and stuck them on my lg4 it would run better?....the l98 car has only 63,000 miles on it and everything looks almost brand new....but...u think it would help my lg4.....the l98 was flipped leaving me to beleive id need to rebuild it....what do u guys think???
Dan......
Old Jun 18, 2001 | 12:21 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The LG4 is a 305? If so, you'll lose compression ratio, you may make up some in the better flowing L98 heads.
For all the work to pull two sets of heads and install another, I think I'd pull the L98 from the parts car, pull the pan and have a look at the bearings, if they're okay, then install that motor.
Car's don't run too long when upside down, a few minutes at most, and probably at an idle RPM speed, probably enough oil still on the bearings and enough left in the pump to keep things from getting trashed.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
