Anybody using Holley Annihilator ign.'s?
Old Jun 17, 2001 | 10:27 AM
Jason M 91Z's Avatar
I've been reading up on ignitions lately, and was wondering your opinions on the Holley's. I know it sounds dumb, but I want a black coil and ignition box to match everything else under the hood. I want to open the hood and for people to see a stock looking engine without red blue and yellow accessories. How do the Holley's compare to Crane? TIA everyone.
-Jason M. 1991 Camaro Z28
Old Jun 17, 2001 | 11:29 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I have the 100model. They are all basically the same. The holley puts out a little more voltage (535 i think). I like it bc the rpm limit is easy to change. But, it dont matter much now bc my car is not running.
Old Jun 17, 2001 | 12:04 PM
Are you using a lasershot coil too, or the original GM coil?
Old Jun 17, 2001 | 12:20 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
yep, I got the coil. managed to fit it right between the distributor and the windsheild wiper motor.
Old Jun 17, 2001 | 01:30 PM
Do you think there'd be any ill effects to mounting the Laser Shot coil to the engine? I was thinking of making an aluminum bracket to mount it where the stock coil mounts. Do you think the vibration would be bad for it? I'm assuming its just a wireround coil like the stocker.
Old Jun 17, 2001 | 01:58 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Well, it is a wire coil. I think they call them E-coils (for epoxy). And they are supposed to withstand some viberation. But, in some cases, vibs will knock them out. With rubber engine mounts you should be ok..
Old Jun 17, 2001 | 02:01 PM
Cool, thanks for all your help bro.
Old Jun 17, 2001 | 06:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use the street/strip one in my race car. I was originally going to get the MSD digital 6 but I like the features more on the Holley. Controls 2 programmable shift lights, 3 step rev limiter, ignition start retard. No "pills" required since it's all digital.
You should change the coil since the Holley ignition recommends a Capacitance Discharge coil to work properly. A regular coil will work but I melted a distributer cap the first time I tryed that.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jun 18, 2001 | 02:35 PM
Thanks for the input Stephen, I'm leaning toward the Holley myself. Thanks to jcb also.
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
