flexplate compatability
Old Jan 10, 2005 | 11:12 AM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
i have an 87 350 i'm building and i'm going to have it balanced. i have a big flexplate that came with the engine but I need a small one. i have a small one for an older engine and since i'm going to have it balanced will the old one work?
Old Jan 10, 2005 | 11:19 AM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
I would just take it all in to the place thats doing the balancing and ask them.They should know what works and doesnt right?
Old Jan 10, 2005 | 11:29 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The one off of the 87 should be for a 1-piece rear seal and have an external weight welded on it near the outside of the flexplate. Older flexplates for 2-piece rear seals have no weight and a different bolt pattern and will not work.
Old Jan 11, 2005 | 08:03 PM
TheViper's Avatar
Car: '84 Z28
do i realt need a small one? i mean, the body of the starter would be more in the way than the flexplate wouldn't it?
either way i know i'm going to need a mini starter. would it still be in the way?
i'l be using hooker shortie headers if it makes a difference.
Old Jan 12, 2005 | 08:42 AM
Lo-tec's Avatar
The only way to know would be to mock it up with the headers. The starter will sit further out with the larger flexplate. Personally, I would use a small one.
Old Jan 12, 2005 | 10:40 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Pioneer p/n FRA-160. $44.95 at Autozone.
Guess how I know?
(Edit: Guess how I goofed? Correct p/n now listed.)
Old Jan 13, 2005 | 08:19 PM
TheViper's Avatar
Car: '84 Z28
well, i just ordered one from jegs so i guess that problem is solved.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
