Gm Hot Cam in a pre87 block?
Old Jan 10, 2005 | 03:51 PM
Zeder's Avatar
Has anyone put a GM Hot Cam in a generation 1 SBC. I was thinking of doing a roller conversion and I happened across the Hot Cam from a friend of mine. Has anyone tried this?
Zeder
Old Jan 10, 2005 | 04:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It would work, if:
1. you used "retrofit" roller lifters; and
2. you used the factory roller type of timing set; and
3. you made a spacer to simulate the thickness of the factory roller system retainer plate; and
4. you used a traditional cam button.
Seems like an awful lot of trouble to go through, just so you could use an inferior cam. https://www.thirdgen.org/techbb2/sho...hreadid=273180 After you buy all the expensive stuff, you can buy the cheap part (the cam) from somebody else, that will work a helluvalot better than that little stockish cam ever will.
Old Jan 10, 2005 | 04:51 PM
Zeder's Avatar
Thanks for the fast reply. I know I could go to a more agressive cam, but the hot cam should give me a pretty stable idle and still give me some pull. The motor I am thinking of doing this to is a 2 bolt main, so I really don't want to rev the crap out it. I have Perf RPM heads/intake carb and I already have the 1.6 RR. I am wondering how the cam would wake up this setup. Right now I have a XE250H flat tappet cam. Nowhere near enough lift and duration for the capabilities of the heads. This is why I would like to try the roller approch.
Zeder
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
deracer
Apr 11, 2016 12:04 AM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
