Crane Compucam 2032 will it fit in 87 305 with stock heads??
Old Jun 18, 2001 | 11:31 PM
Ant87IROC's Avatar
Car: 87 IROC Z28
Transmission: TH700R4
Hey, I was wondering if the cam I ordered will work ok in my 87 305 TPI with stock heads?
Description = Crane Cams CompuCam Cams Factory hydraulic roller for 87-89 Corvette & F-body w/350 TPI. Adv. Duration: 270º/276º Gross Lift: .452''/.465'' Series: 2032HR
This should have been something that I looked into more thoroughly before i ordered it.. I just want to know if im gonna have trouble or cause any damage to the cam or the valves... thanks!
Ant
87 IROC 305 TPI
[This message has been edited by Ant87IROC (edited June 18, 2001).]
Old Jun 19, 2001 | 01:31 PM
87formula's Avatar
I had the same cam I do now in my 305 when it was stock heads and valve covers, I had no clearance problems, I belive it was the Compucam 2030 but check my sig for sure, Also just to let you know you don't have to replace the roller lifters, it is a good idea, but since they roll they don't wear in like regular lifters. Any more questions send me an email.
1987 Firebird Formula
305 LG-4
GM Vortec heads 2.02x1.6 valves
Crane CompuCam 2030
700-R4 Trans
4 barrel quadrajunk remained by holley (this carb stinks!!!)
edelbrock performer intake
Hypertech Thermomaster Chip
Open Element Air Filter
No Cat with Straight pipe (Dynomax muffler rusted apart and fell off probably could not stand the heat )
Accel H/P Coil
- Soon to be installed
383 stroker (built and ready)
NO MORE COMPUTER CRAP
700R4 Lockup kit
Edelbrock TES
True Dual exhaust or 4 inch single pipe to dual 2 1/4"
Stall convertor
Jeremys87
Jul 14, 2022 09:08 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
mustangman65_79
Aug 8, 2015 01:18 AM
