very low vacuum
Old Jan 12, 2005 | 09:01 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
very low vacuum
would low vacuum cause a TBI car (89) to run excessively rich, when I say low it's around 12 inches of vacuum, also when I come to a stop my brakes barely stop the car and become very hard to push.
what could cause this I see no vacuum leaks anywhere, maybe this explains my car failing smog bad
Old Jan 12, 2005 | 09:07 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Low vacuum would run on the lean side. When a vacuum leak occurs, air is getting drawin in from a location other than what is metered by the throttle body. Under normal conditions, you increase air volume, you increase fuel. It's a ratio set by the computer. Any air beyond this is unaccounted for and the amount of fuel is not increased. You run lean.
Not certain about the rest. Perhaps you could try in the TBI board. Shifty and co. really know their stuff over there.
db057
Apr 28, 2019 07:45 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
amcnellis
Sep 16, 2015 04:16 PM
adelane
Sep 9, 2015 08:51 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
