Bolt keeps loosenign, anything i can do?
Old Jan 15, 2005 | 10:13 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Well my header flange (2 bolt kind) bolts on the passenger side keep coming loose, and it seems like every 2 months I am driving down the road when they completely let go.
So tomorrow I got to wake up really early and fix the darn thing before I get to work.
This time when I fix it, are there anythings I can do in particular to make these bolts stay tight? At those temperatures superglue (or even lock tight) wouldn't work. What else can I do?
Shane
Old Jan 15, 2005 | 10:57 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Stage 8 locking header bolts will fix you up. The are only about 45 bucks for a set.
Old Jan 15, 2005 | 11:19 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
I don't think it's a good idea to use superglue on bolts lol.
How about hi-temp threadlock?
Old Jan 16, 2005 | 12:20 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
get a hi heat locktite
only way to fix it
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Weld the nuts to the bolts after tightening.
Old Jan 16, 2005 | 12:34 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
:lala: :lala: :lala:
Old Jan 16, 2005 | 12:55 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
good idea
Old Jan 16, 2005 | 12:59 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Get header bolts with holes drilled in the heads for safety wire. Then buy some tie wire from, well, anywhere, and thread it between two bolts to 'tie' them together. They will not ever loosen, and if you need to take the bolts out, you dont need any weird tools or special waste-your-time techniques. Just cut the wire and grab a wrench to take them out.
Old Jan 16, 2005 | 01:00 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well i;ve always been told that locktight is just like super glue, so i figured of its like super glue, and super glue cant take 1k* temps, then why would lock tite.... i guess i'm wrong, i'll stop by autozone tomorow and see what they got for me then....
Old Jan 16, 2005 | 01:04 AM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
keep tightening them
Old Jan 16, 2005 | 01:31 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
High-temp loc-tite or tack weld the nut once you tighten it.
The bolts shouldn't get to 1000* I wouldn't think.
Old Jan 16, 2005 | 03:07 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'm amazed. Stunned. He's getting better. Now if we could only get him to search.
Many of these are sound advice. I'm cheap and just check 'em now and again. Lock washers seem to help, for a while, as well.
Old Jan 16, 2005 | 05:39 AM
ede's Avatar
ede
use better gaskets and better bolts. if you don't want to go the high dollar stage 8 route safety wire is cheap and easy, at least for some of us. on the plus side not much looks any better than a good safety wire job on something.
Old Jan 16, 2005 | 08:14 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well i did a wuick fix today, found a bolt long enough and fit it in the nut thats already welded to the flange.
Tomorow since i goto work at 11, i'll go try and fid some of these bolts with holes at the end, thats actually a pretty swet idea....
Thanks for all the help guys....
shane
Old Jan 16, 2005 | 09:01 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
I cant wait to see the next thread asking how you get the wire thru the holes in the bolts ...do you have to spit on it or somfin d00ds?.....when will it ever end
Old Jan 16, 2005 | 09:35 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
or which way to route the wire around the bolts, etc...
How many threads is he going to start about safety wire?
Old Jan 16, 2005 | 09:48 AM
THEGENERAL's Avatar
I say atleast 3 if not 4 by the end of the weekend....LMAO
Old Jan 16, 2005 | 10:12 AM
bru333's Avatar
Car: 1987 Camaro SC
safety wire
safety wire 2
Just for fun. Let's see if he'll read first!
Old Jan 16, 2005 | 10:32 AM
THEGENERAL's Avatar
safety wire
safety wire 2
Your kidding right...LOL...we all know better than that...
Old Jan 16, 2005 | 11:11 AM
bru333's Avatar
Car: 1987 Camaro SC
:yes:
Yeah, and he drives me crazy. I've only started 2 threads here because I can usually find what I need by
But he's not the only one that posts a lot. "V8 Slayer" has quite a few threads too.
Or is that one of the alias that Shane uses?
Old Jan 16, 2005 | 01:42 PM
Air_Adam's Avatar
shane
It works really well. My dads '73 Z28 used them and he never had a problem. I'm not sure if he bought them (bolts) like that, or if he had to have them drilled though, but I'm sure you can buy header bolts like that. It seems like enough people have done it.
Old Jan 17, 2005 | 07:32 PM
big_fart_buster's Avatar
do you folks know where I can get some of that "thread" you all keep talking about?
I can't start any of my own lines cause of having none of that thread stuff.
Is it thread or tread? Seen it both ways.
Old Jan 17, 2005 | 08:37 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Puff, puff, pass.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
