oil leaking from head gasket?
Old Jan 16, 2005 | 03:49 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
at the front drivers side cylinder i see oil looks like seeping from the head and the block. i pulled the plug and its fine i did a compression check, its fine as well. is it possible to leak like that? i guess its time for new headgaskets?
Old Jan 16, 2005 | 05:18 AM
ede's Avatar
ede
pretty much no chance in the world oil would leak from a head gasaket. there's no oil in the head, other than the drain back holes and that oil isn't under pressure.
Old Jan 16, 2005 | 12:40 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok thanks
Old Jan 16, 2005 | 06:30 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
look to the very corner where the block head and intake meet. that is where your oil is coming from. you need too put a lil extra silicone in the 4 corners to help avoid the exact type of leak you are having.
Old Jan 17, 2005 | 07:27 PM
big_fart_buster's Avatar
hey you guys think that silicone from used breat implants will work?
I got access to some of them and was wondering it it would pretty guud.
Old Jan 17, 2005 | 10:33 PM
Vader's Avatar
No, that would be self-vulcanizing silicone sealant, not pure silicone lubricant. Thanks for the offer, though...
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
drathaar907
Aug 6, 2015 04:20 PM
