distributor swap question
Old Jan 16, 2005 | 12:02 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
I need to swap a computer controlled distributor into my 406 with flat-tappet cam. My understanding is that distributor gear needs to be a specific material depeding whether you have a flat-tappet or roller cam.
So, if I go junkyarding/ebaying, what is an acceptable vehicle to grab one from? TBI Camaro/full-size truck? (87-95?) I'm guessing one from a TPI would be setup for a roller cam?
Thanks,
-Dave
Old Jan 16, 2005 | 01:26 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
All f-bodies had roller cams starting in 1987. Trucks, however, didn't get rollers until the early-mid 90s if I remember correctly..
Old Jan 16, 2005 | 01:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
IIRC, a roller cam needs a bronze gear on the distributor, and a regular cam needs just a regular gear. Steel I think.
Old Jan 16, 2005 | 01:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
All factory Chevy V8 distributors from the dawn of time (1955) are compatible with flat-tappet cams.
All of them from about 87 up, and from maybe a few years before that, are compatible with typical hydraulic rollers. They started austempering them, which is a process using molten salt as the quenching bath for tempering; "melonizing" is the brand name of the process they used. They look blue.
None of them, ever, from any year, made out of anything, are comaptible with a real roller (steel billet core) unless the cam has a cast-iron dist gear pressed onto it.
Old Jan 16, 2005 | 02:07 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
What style distributor? HEI large cap or HEI 2 with small cap? You can always just by a new gear for a regular cam and put it on your new distributor.
Old Jan 16, 2005 | 02:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you're using a flat-tappet cam, you don't have to change anything. Whatever gear comes on whatever junkyard distributor you get, will work fine.
Old Jan 16, 2005 | 04:36 PM
Engine: 383, 327
Thanks guys.
-Dave
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
