Intermittent code 43.?????
Old Jun 20, 2001 | 01:06 PM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
I put a new 350 in My 86 Iroc 3 weeks ago and
I am trying to work all the bugs out. This is a new code for me but once in a while I get this code 43. I run new taylor spiral pro's,
new MSD cap and low resistance button, a MSD digital 6 and stock distributor with new plugs. what would cause this?
What size ACDelco plugs should i use with the 350?
thanks
Jamie James
1986 Iroc-Z 305 TPI
1.90 60 ft 14.15@ 95.75
1.74 60 ft 12.84@107.75 on the bottle.
My IROC:
http://personal.nbnet.nb.ca/jjames/homepage.htm
Old Jun 20, 2001 | 03:35 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
It's either a bad knock sensor, bad wire, or bad ESC module. Try bypassing the KS by using a 3.9k resistor in its place, if the problem goes away your sensor is bad. If it doesn't, one of the others is bad.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
[This message has been edited by Ed Maher (edited June 20, 2001).]
Old Jun 21, 2001 | 07:46 AM
KustomIroc's Avatar
Engine: 383 Stroker
Thanks Ed
Much appreciated.
Jamie James
1986 Iroc-Z 305 TPI
My IROC:
Falcon50
Aug 22, 2020 03:26 PM
okfoz
Oct 13, 2015 02:19 PM
Reid Fleming
Oct 10, 2015 09:56 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
