I need a picture of a manual choke setup!
Old Jan 17, 2005 | 04:55 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Hey...
I am in the process of changing my Holley street avenger from electric choke to manual choke. I have it together...mostly. But I cannot figure out how you are supposed to make the fast idle work. I do not see how it could at all. For now I am going to try to get the cable bracket on there and use it. Just wondering if anyone have a picture of a holley manual choke up close so I could compare.
Thanks.
Old Jan 17, 2005 | 05:50 PM
Vader's Avatar
Close enough?
Old Jan 21, 2005 | 01:13 AM
Transmission: 4l60e
hmm...looks like I may possibly have my assembly mounted upside down. And I mounted my cable holder underneath using the very long screws and some nuts I had.
It is working good now. I just can't figure out how to mount up fast idle stuff. So right now I have nothing on that section.
I will take a good look at it tomorrow and see. I do not see how I can mount it like that picture...I will have to check it out and see what I have done. But it is working.
:::edit::: I have the quick change out secondary housing. So I couldn't mount the bracket on it like its supposed to be. But that was just a minor detail.
Old Jan 21, 2005 | 01:32 AM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
You didnt like the electric choke?
Old Jan 22, 2005 | 12:32 PM
Transmission: 4l60e
It didn't work. And barely worked when it was brand new. Sometimes it would stick and not even move. Now it is pretty much locked up. It stuck in the upper most position and can't even be forced to move.
I have had a lot of problems from this holley carb. Damn street avengers.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
chubsworth
Aug 26, 2015 02:34 AM
jahblah
Aug 12, 2015 05:54 PM
