alternator bracket bolt size
Old Jan 17, 2005 | 06:51 PM
rsn932's Avatar
I tried doing a search and could not find anything. Does anyone know what size the bolt is that goes into the bracket that adjusts the tension of the alternator belt? This is for an 87 TPI setup with V-belts (since i think i read somewhere that different years have different brackets). Thanks guys.
Old Jan 18, 2005 | 08:49 PM
Damon's Avatar
That's the bolt that basically just goes through the bracket and into a set of threads cut into the ear on the top of the aluminum alternator housing? If so, I don't think it's anything special. 1/4-20 thread with a 1/2" 6-point head about 1" long available at any hardware store, if I had to guess (don't take my word for it). Should cost you about a dime and 2 pennies.
Old Jan 19, 2005 | 03:23 PM
rsn932's Avatar
yup thats the one. thanks
Old Jan 19, 2005 | 03:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's either 5/16"-18; or it's the common metric size with a 13mm head (very close to 5/16")... I think it's 8mm x 1.25mm but I'm not positive. Yours should be the metric version.
Old Jan 19, 2005 | 03:42 PM
rsn932's Avatar
great thanks rb
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Genopsyde
Nov 11, 2015 10:46 PM
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
knight72
Aug 10, 2015 09:32 PM
