Tell me it's not....
Old Jan 19, 2005 | 09:38 PM
BadBowtie88's Avatar
Here's the story. Yesterday my car's temp got up to around 220-230* on the way home from work. I think the thermo was stuck on it. It was only there for a very short period of time. I would have shut it off, but it dropped back quickly. Well, tonight I went into town to get taxes done and I noticed it was running really crappy. I got home and got out and guess what I see? White smoke billowing from the exhaust. I got it inside my shop as steam starting comin up from underneath the hood as well, not alot, but some. Water is definitely leaking from the back of the motor somewhere. White smoke is usually an indication of a cracked head or blown head gasket right? I can only pray that it's not a cracked head, considering I have $1500 wrapped up in my heads! Input? Comments?
Old Jan 19, 2005 | 09:52 PM
Vader's Avatar
Even in Missouri, this is "thermostat" weather. A lot of them will stick under these conditions. If your dash guage showed 230°, the coolant may have been at 230, or may have been much warmer or cooler. If you have an obvious coolant leak, you need to repair it. Whether it is due to damaged castings, leaking intake gaskets, or even a loose heater hose will be up to you to determine.
I can't however, tell you with any certainty that "it's not..."
All we can do is hope for you that it "ain't so".
Old Jan 19, 2005 | 09:53 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
Check your oil dip stick for a milky looking film.
Old Jan 19, 2005 | 11:20 PM
matts90firebird's Avatar
and under the oil fill cap
Old Jan 19, 2005 | 11:57 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
AFR's are nice and thick so you shouldnt have to worry about them being trashed
beav1993
Sep 3, 2013 04:46 PM
dredre08
Feb 5, 2012 06:57 PM
wildstar
Dec 22, 2011 02:02 PM
mrfrankmrfrank
Members Camaros
45
Aug 11, 2011 12:17 PM
gotabekidding
South East Region
Jul 3, 2011 07:49 PM
