Whats makin this 4.3 smoke like a bitch?????
Old Jun 22, 2001 | 12:54 PM
CamaroZ_85's Avatar
My friend has a 91 S-10 w/ a 4.3 that uses a crap load of oil. Here's the deal....it smokes a little bit when you first start it (like it's vavle stem seals) but not when it's under varying RPM's like when you're driving. But if it idles for a few minutes, and you hit the gas, it gives a nice puff of smoke again. whats the deal w/ this, do you think it's rings dying or the vavle stem seals??? his dad thinks it's the seals but i was thinkin rings cause of the smoke it'll give after it's running for a while (like i said, only after it idles...not during regular driving) i guess the best thing to do would be a compression test to rule out the rings...but what do you guys think?????
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
[This message has been edited by CamaroZ_85 (edited June 22, 2001).]
Old Jun 22, 2001 | 01:14 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Compression test is a good plan. Also check the PCV valve. Might be stuck, and just sucking oil out of the motor at idle.
Good luck
Old Jun 22, 2001 | 02:41 PM
Bort62's Avatar
My car does the same ****, when I hit the track lastime i ran my 14.8 mostique fogging all the way down.
I dunno what it is, Either leaky intake, PCV, extreme valvestem seals, or Bad rings.
Im pretty sure my rings are okay, so I think its the Intake, weeee....
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jun 22, 2001 | 07:27 PM
82camaro's Avatar
Car: 82 camaro SC
Check the stuff above. Just like to add: With OK compression on the compression test and good power, the oil control rings could still be stuck or broken or worn out. Right off idle and when shifting could be valve guides/seals. I really, really doubt valve seals will fix the problem if it's smoking that much--if it's coming down the valves that much the guides are probably shot as well as the seals.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
