Trick flow heads
Old Jan 21, 2005 | 12:52 AM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
Trick flow heads
Hi guys quick question on pushrod length.Ive got a 90 roller 350 engine and im using trickflow heads and need to know if i can use the stock length pushrods or if i need longer.Is there anyone else using this combo?
Old Jan 21, 2005 | 06:44 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I have the 23* heads, not the twisted wedge ones and use the stock length. I did use an adjustable first though and verified that it was the proper length. Mock it up with stock ones and check your geometery.
Old Jan 21, 2005 | 09:20 AM
Car: 1983 Z28
Engine: 383
ok thanx im running the same heads and just wanted to be sure i didnt need any exotic lenth pushrods trick flows sight doesnt have info on these heads anymore that i could find.
Old Jan 21, 2005 | 11:53 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
http://www.trickflow.com/product/che...r_23degree.asp
Shouldn't be exotic, but stock may not be right either.
Old Jan 21, 2005 | 08:14 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
here's info from the stuff that came with my heads: (TFS-30400007-CNC)
first before i retype the chart, be it known that i am running crane gold race rockers, with a comp cam roller cam.
i am using 7.4" pushrods, which are pretty much dead on for my combo. they also happen to be the suggested ones for that setup.
THE FOLLOWING IS FOR USING ROLLER ROCKERS: CRANEGOLD, TFS OR SUMMIT "BLACK" ROLLER ROCKERS.
for a standard hyd flat tappet cam, trickflow recommends 7.8"
for standard solid flat tappet, trickflow recommends 7.9"
for GM or Crane hyd. roller - 7.2"
for Comp Cams or Crower hyd. roller - 7.4"
THE FOLLOWING IS FOR STAMPED STEEL ROCKERS
Standard hyd flat tappet - 7.550"
stock GM hyd roller - 7.150"
Basically, i would get everything put together and figuer out the pushrod length before ya order em....
Steve
Old Jan 21, 2005 | 08:44 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I'm running the LT4 Hot Cam so stock length would make since.
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Ducati900ss
Sep 2, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
