Help me pick a fuel pump, AFPR, and rockers...
Old Jun 22, 2001 | 08:53 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I was looking at the Holley in-tank fuel pump for my new 383....anyone have experience with this one. Any other suggestions for intank pumps. Also which AFPR is easiest to adjust? Finally I want to get roller tip rockers that will not interfere with stock valve covers. Who has some that will work?
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Old Jun 22, 2001 | 09:27 AM
Car: 89 IROC-Z
Engine: 383
I forgot to mention that the rockers should not be self aligning because my AFR heads have pushrod guide plates.
Old Jun 22, 2001 | 10:04 AM
ede's Avatar
ede
i'd run comp rockers, the full needle bearing ones. for a fuel pump i'd consider an external eletric. i have a holley on my car. more work to mount but lot easier to change if there's a problem.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 22, 2001 | 02:55 PM
Car: 89 IROC-Z
Engine: 383
I really wanted to keep it internal, but I'll consider it.
Old Jun 22, 2001 | 10:42 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Theres a guy on the web saleing the walbro 255lph pump kit for 93.00. Heres is a link:
http://members.home.com/syclone/APE/...p.html#payment
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jun 23, 2001 | 02:04 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
As far as the AFPR goes I have a holley that I am going to be installing tomorrow. I personally think that it is going to be the easiest to adj because it has a flat top that you turn with your hand with no wrench at all.
Old Jun 23, 2001 | 03:32 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Yeah... that holley looks like a nice design. I would like to know how it works out for you. That has always been the thing with the adjustable regulators. Trying to reach the nut or allen screw to turn them. The one I had on my TBI on the RS was the hardest to reach. The TPI system on the IROC is easyer.
I was thinking of using a piece of sheet metal. Knurling the outer rim and brazing it to the nut on my adjustable one.
Old Jun 23, 2001 | 04:01 PM
Jason M 91Z's Avatar
Take Mike's advice and get that Walbro 255. I bought mine from Ron over at APE also, and it is in fact $93. The Holley pump is actually a Walbro pump, only difference is it comes in a Holley box and has the Holley price.
-Jason M. 1991 Camaro Z28
Old Jun 23, 2001 | 05:18 PM
Car: 89 IROC-Z
Engine: 383
Ok I ordered my Walbro pump today and I'm going to get the Holley AFPR....I've heard about their ease of adjustment too. Now I just have to decide on those rockers.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
beachrodder
Aug 25, 2015 08:05 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
