when is it time to get a new distributer?
Old Jun 23, 2001 | 01:54 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I'm sure my disributer is as old as the car,what kind of problems will worn bushings,pick-up magneto ect... cause? how can I tell if the distributer is still good enough to keep the rotor spining precisely where it should?
Old Jun 23, 2001 | 05:47 PM
sleeper's Avatar
When you dissasemble it check the main rod for signs of scoring and a loose fit. If the rod is pited, scored, or sloppy when jiggled then you need a new rod.
You will never get the timing right with a bad distributor.
1986 Trans Am
carbed 350 - .30 over with 9.75:1 comp.
+- 315hp/390ft lbs.
700-R4 with 2500 stall
3.27 (ick!) gear
SLP 1 3/4" headers w/MAC catback and cat.
96 5 stars
SFC's, braces, arms, and a bunch more expensive stuff
no timeslips yet
Infested
May 22, 2018 11:56 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
