rebuilt motor sound
Old Jan 22, 2005 | 09:36 AM
87camaro kid's Avatar
Car: 1987 Z28
rebuilt motor sound
i just put in a rebuilt 350 into my car i put all new bearings and double checked that i tourqued everything down right. the car starts and idles fine but i cant give it gas or it dies...i think i still gatta adjust the feul and timing and valves but thats not my qustion...from the balancer and pully its making a ratling sound when the car is running and i just took a closer look at it today it looks like the pully and balancer arent on streight or something cause it wobles a little could that be the noise?
Old Jan 22, 2005 | 10:12 AM
Car: 1987 Z28
i was alos thinking mabey the timing chain?
Old Jan 22, 2005 | 12:09 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The first issue is most likely caused by a combination of timing and carb adjustment.
The ballancer is starting to slip off the rubber ring casuing it to wobble.
The rattling sound could be a number of things, could be the ballancer causing some odd vibrations, could be the timing chain has too much slack in it. There are too many different rattling sounds an engine could make to give any hard suggestions without hearing it first hand, fix the ballancer and work from there.
Old Jan 22, 2005 | 02:09 PM
Car: 1987 Z28
its a TPI...should i get a new balancer?
Old Jan 22, 2005 | 11:10 PM
Car: 1987 Z28
also one other thing when i turn the car both fans turn on to y does it do that?
Old Jan 23, 2005 | 02:35 PM
Car: 1987 Z28
any one?
italiano67
Dec 11, 2016 09:21 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
355sbcTPI
Aug 19, 2015 04:38 PM
