What You Guys Think???
Old Feb 3, 2005 | 06:30 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
well i just picked up a set of ProTopline Vortecs for 450 bucks. Heres what my setups gonna be
-350 block .040 over for 357
-ProTopline Vortecs With .600 Lift springs, screw in studs, guideplates
-Performer RPM Manifold
-1.6 Roller Rockers
-Crane BlueRacer .465/.488 290/300 Adv (soon to be XE274)
-Speed Pro Coated 10.5:1 Flat Top Pistons
-Steel Crank
-6 Quart Oil Pan with windage tray
-Holley 650 Double Pumper-(soon to be prolly 750 Demon VS)
-BTO Level 2 200-4R
-9.5" 2800 stall converter
Think i should be around 400 HP with this setup? Can you guys see anythign i should change?
Old Feb 6, 2005 | 09:59 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
bump
Old Feb 7, 2005 | 06:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If this is for racing, stick with the DP carb.
Old Feb 7, 2005 | 08:18 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
this is for a daily driven street/occasional strip car so thats why i may go to the VS demon for a lil more mileage.
Old Feb 14, 2005 | 11:32 AM
Tech @ BG's Avatar
With a 2800 Stall speed you're on the borderline between using a mechanical secondary and vacuum secondary. If you stick mechanical secondary a 650 is a better choice. It will give you crisper throttle response, and acceleration, while the larger vacuum secondary carburetor will give you a little better top end.
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
