biggest cam in stock heads?
Old Feb 5, 2005 | 12:57 PM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
ok i searched and didnt come up with a very solid answer
i have a 84 LG4 5.0 with stock heads, whats the biggest cam i could run without replacing the valve springs?
ive been looking on jegs and crane energizer cams have a bunch of grinds in the .450-.480 range which is what im guessing is the range of the biggest lift i could get
one im really looking at is .467"/.467" 278*/278*
would that be a good cam to run, as far as actually fitting in the motor and not having issues?
Old Feb 5, 2005 | 01:02 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
At .467" lift , it will fit. You can get hi perf springs that will drop on to replace the tired stock ones too. You can replace the springs without removing the heads from the motor too.
This cam would require a high rear gear ratio be used behind your stock 305. You'll see a significant loss of low end torque below 3000 rpm, but above 3000rpm, a gain.
Should rev to 6000rpm. I'd switch to 4.10's
Old Feb 5, 2005 | 03:16 PM
PhantomFE3's Avatar
Car: 1984 Z28
on jegs it says the RPM range is 2400-5400 so thats about right, if i can get a hold of a 4.10's then ill get em but we'll see, dont know if any of the junkyards around here have them
Old Feb 5, 2005 | 10:04 PM
F-BIRD'88's Avatar
The "rated rpm range" will be a little higher in a 305. You can find 4.10's in S-10 trucks
Old Feb 5, 2005 | 10:52 PM
PhantomFE3's Avatar
Car: 1984 Z28
i have a 92 sonoma right now, how do i found out what gears i have in it? i know its not a posi because i do 1 leggers all the time, its a 92 sonoma 4wd with the 4.3 v6 if that helps any
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
