My car hesitates when the AC is on, why?
Car: 1989 Trans Am GTA
Engine: 5.7 Liter
Yesterday while I was driving my car on the highway, I had the AC on and I noticed a slight hesitatation or lurching. When I turned off the AC, the problem went away. I was wondering what causes this, and if it's normal.
Car: 82 camaro SC
It may have been the A/C compressor kicking in or out. Which is no problems unless it does it rather quickly--which indicates a low freon level.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
Linson
Aug 21, 2015 02:12 PM
ac, air, car, conditioner, conditioning, engine, hesitate, hesitates, hesitation, hessitate, older, on, start, transmission, turned
