High Rpms?
Old Feb 6, 2005 | 10:00 AM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
High Rpms?
When I start my car the engine will be normal at idle around 750 but then will jump to almost 1500 rpms what's up with that? I'm not getting and engine codes but any suggestions?
Old Feb 10, 2005 | 04:37 PM
Vader's Avatar
With factory programming, the idle should be high when a cold engine is started. Target idle RPM will slowly drop based on a timer and the CTS input. If the CTS is not warming up, the idle will remain high.
Old Feb 11, 2005 | 12:28 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
hmmm what is CTS?
Old Feb 11, 2005 | 12:36 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Coolant temperature sensor. Its on your waterpump. I'd replace it to be sure, I think they are only $15.
Old Feb 11, 2005 | 06:13 PM
my 82 trans am's Avatar
Car: 1990 Camaro RS
Engine: 5.0 liter TBI
Transmission: Borg Warner T-5
i had to replace my cts. 8 bucks. it went out completly.
it fixed it
Old Feb 12, 2005 | 07:24 PM
GokuZ06Roc's Avatar
Car: 87' Iroc-Z
hmm i'll check to see if that's what it is but i've just had all that stuff replaced rather recently so i'll check into it....
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
