Voltmeter. What reading normal, key on ?
Old Jun 25, 2001 | 03:56 PM
GTA88's Avatar
Meaning, when I have trhe ignition on, but car not started, what should be the reading on the voltmeter for a healthy battery? When I do this in my GTA, it reads only 9 to 10 volts. I put in my other battery from my daily friver and it had just 10 volts. Are both these batteries getting low ? Should the voltage read 12 for a healthy battery ?
88 GTA Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Old Jun 25, 2001 | 04:01 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Check the voltage at the battery w/ a real voltmeter, dash guages are notoriously inaccurate. If either of those batteries can start a car they have better than 12V, not 9 or 10.
I know a healthy battery will have some change over 12V at rest. If it is near/below 12V it is probably dead. At least thats been my experience. With the car running you should see 13.8V+.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jun 25, 2001 | 04:47 PM
greearhr's Avatar
The volt meter in my 92R/S reads exactly the same. You are OK, the meter's a piece of crap.
Beartracks
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
GTAman
Mar 15, 2019 11:40 AM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
