Vats
Old Feb 7, 2005 | 05:07 PM
tb8125's Avatar
Vats
When did GM start to use VATS in their car F-bodies and Y-bodies
just bought a 85 vette motor for my 88 camaro and was wondering if VATS was going to be a headache for me
and why is that the 85 F and Y bodies ecm won't work with any 86 to 89 harness is it because of VATS will a 88 harness and ecm work with this motor
Old Feb 7, 2005 | 07:51 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
The 85 Vette would not have a Vats system. Camaros started using it in 89, so you should have no problems with that. GM improved the tpi about every year so, maybe the computer may be the same for some years, the program chip would be different. The 85 engine was wired quite a bit different than later years.
Old Feb 7, 2005 | 08:27 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
'88 in the f-body. (more common on the later production gta and irocz)
85 had a differant maf system
86-88 are very similar almost identical (programming was about the only differance
89 they removed the cold start injector
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
