Is the ECM adding to much timing at idle?
Old Jun 25, 2001 | 05:54 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I set base timing at 4-6* advanced. Reconnected the EST wire and the ECM added 20* or more on top of that. That can't be right can it, at only ~1000RPM's
Would it do this if it detected a lot of extra fuel?
Or it probably would do this if the TPS sensor was reading to high. Right?
Old Jun 25, 2001 | 11:27 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Did you disconect the white wire when you did the timing and when and if you did, did you disconnect the battery to reset the computer memory.
Old Jun 26, 2001 | 12:29 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That may be about right at 1000rpms, once the EST is reconnected the computer will advance timing to the best possible place for complete combustion.
FWIW, with my EST connected at 725-750rpms, my timing is around 14-16*BTDC.
Old Jun 26, 2001 | 09:38 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Yeah thats about right, the PROM has about 20' of timing on top of the initial in the idle region. It's completely normal.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
