327 large journal interchangable with a 350???
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Yes. Both engines use a 4" bore. Some large journal 327 blocks have the same casting numbers as 350 blocks. A 350 is just a stroked 327. The shorter stroke can let the engine rev higher allowing you to build HP at a higher rpm. It won't have as much torque as a 350. Look at SuperStock entries. Many of the GM cars will use a 327 instead of a 350.
You'll need to use 327 pistons also with the shorter stroke 327 crank. Since the con rods are the same length, the wrist pin location on the piston is different.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
