Lug Nuts Please HELP
Old Jun 26, 2001 | 04:20 PM
da BEAST's Avatar
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
I bought a GTA and did not notice that the owner did not give me the special wrench to take off the theft proof lug nuts. Do any one know how to break them off. Is there such a tool out there that will crack them or any other little secerts to goet them off. I got a socket that snugly fit and bang it on with a hammer but no luck. Please help.
Old Jun 26, 2001 | 05:54 PM
David Petersen's Avatar
I had the same problem and found the answer in the arcives using lug nut as the search word if I am unclear. But basically I just used a deep socket that barly wouldn't fit over the lug nut and hammered it on and used a 1/2 inch wrench to turn them off. Also tightening the other 4 lugs will help to loosen the one locking lug.
Old Jun 26, 2001 | 05:56 PM
One Eyed Jack's Avatar
I'd take it to a dealership and see if they could match them.
Old Jun 26, 2001 | 07:45 PM
Gta-Paladin's Avatar
I have the lug key, but remember when you do get them off and you do purchase new lugs you'll have to order them from a dealership because of the lug caps the GTA has the lugs for the gta have threads on the top of the lug for the caps to go on....
that's my personal experience
Old Jun 26, 2001 | 09:48 PM
82camaro's Avatar
Car: 82 camaro SC
If it's really tight/frozen, have a shop weld nut on it and unscrew it. Napa, and other stores, carry the external thread lug nuts. As well as the caps.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jun 26, 2001 | 09:56 PM
zee28's Avatar
Car: 86 iroc
VISE GRIPS.I had to do it on my wifes 87 firebird.Wrap the pliers with a rag so you dont scratch the wheel.It will work if its not to tight.I couldnt believe it.
~mike~86 IROC-Z
timonator
Sep 30, 2015 12:52 PM
gord327
Sep 29, 2015 10:18 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Fox118
Sep 12, 2015 09:29 PM
fasteddi
Sep 10, 2015 09:32 AM
