radiator cap question
Old Jun 27, 2001 | 03:36 AM
burnoutrpm's Avatar
ok theres my problem........i havea griffin dual1" core all-aluminum rad and i have a "new"16lb cap for it when ifirst put the rad and cap in it ran hot...then i put 2 pinhole in the rad tank......AND IT RAN COOLER?!!wtf? so thinking the holes were letting off pressure and keeping the car coller i was in a pickle wheter to get a coller(lighter lb cap) or heavier lb cap so i bought a 13lb andn it cools ....well better but, still gets hot in dead idle circumstances? what damn lb cap do these rad's need?????should i go yet coller or heavoer? 16lb was stock for my car.oh yeah im rnnning dual fans(electric)1 14" and 1 12"
fan. heres another interesting fact no matter the mix of antifreeze to water i try the rad wont cool with anything BUT, pure water?why??
thanks!
89 firebird formula
360 10:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1405edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!.with lots of NOS
Old Jun 27, 2001 | 07:14 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
The higher the pressure in the system, the higher you raise the boiling point so it should therefore cool better
The only drawback to high pressure is blowing hoses out and finding mushy soft-plugs.
I'm running the griffen w/o any overheating probs. I'd look into the thermostat or water pump. Another thing that happens frequently is the bottom hose gets sucked shut, restricting the flow.
Is your motor in tune? Not running rich/lean?
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
