Fuel Pump ??
Old Jun 27, 2001 | 03:19 AM
83_TA's Avatar
Fuel Pump ??
I have an 83 Trans Am, 305 LG4.. Just had the motor rebuilt, also new exhaust & ignition system..
Problem I'm having is it Boggs at WOT from a dead stop.. It's a new intake & new edelbrock #1406 (600 cfm) carb.. Everything has been tuned as much as possible..
Could this be a fuel pump problem? If so, what would be a replacement? I've seen the in tank and inline fuel pumps, which do I have now..
I haven't tryied re-jetting the carb yet, but it just seems like it's starving for fuel at WOT..
Old Jun 27, 2001 | 12:40 PM
GTA88's Avatar
Sounds like the carb still needs tweaking. There is a tech article in 3rd gen about carb tuning, and it specifically mentions bog , especially with 4 barrels.
Old Jun 27, 2001 | 12:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You have the block-mounted mechanical type of pump. It will not cause that problem.
Oops, I just re-read your post, you have a Carter carb.... the rules are different for that. You'll probably need to get the tuning kit from Edelbrock to get it really right.
ICON Motorsports
[This message has been edited by RB83L69 (edited June 27, 2001).]
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
