Fuel problem....
Old Jun 28, 2001 | 01:16 AM
bfoleyiii's Avatar
Fuel problem....
Ok, the car has been acting up for the last month or so now. Randomly stalling, but when I get back to it with some tools she fires right up and works for a bit, then stalls. Well tonight me and some carb cleaner finally discover that it is a fuel problem. Filter was changed, which pretty much to me leaves (not that I am all that swift) the pump, carb (maybe the float sticking or out of alignment), or vapor lock.
What is vapor lock. How big a deal to replace the fuel pump, stock mechanical. I rebuilt the carb about 3 years ago and it seems to have been fine since, shouldnt it go out sooner or last longer?
**MOD**
If this should be somewheres else, like Carbs bounce me over, I will not pass go I will not collect 200 dollars.
TIA
Bob3
Old Jun 28, 2001 | 02:34 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Replacing the fuel pump is not too hard.
My brother changed mine last October, took him a couple of hours since he's never done that before.
If your car doesn't have the smog pump and hoses, you can literally change it from above, it's just 4 bolts and 2 hose clamps and one screw-in fitting. I took mine off a couple of weeks from above, just reached down, undid the hoses and bolts and blocked it off. Now I have my TPI, which is almost done now.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Jun 28, 2001 | 02:52 AM
Bort62's Avatar
I replaced mine in 15 minutes in a parking lot In the Dark with Vicegrips...
Course I don't have any smog **** installed, made it a world easier
Oh yeah and the cam lobe just happend to be in the right position hehe
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver 14.82 @ 91.1 (faster than Ed)
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
