Help Quick!! Megashifter is stuck in Neutral!!
Old Jun 28, 2001 | 04:58 PM
Dana'86_305's Avatar
Ok i am picking up my car at Maaco today after they had it a month and when the guy brought it around front he tried shifting it (B&M console megashifter) back into park, and it wouldn't budge past neutral and now the t-handle (part to pull up to put into gear) is stuck down and won't shift. Is the cable kinked or is the problem in the shifter itsself. I've had it over a year and it was professionally installed. This is the first problem i've had with it. Maaco is getting a mechanic to look at it tommorow, but i'd like to have some ideas about what they should do. And i wanted my car back today sooo bad!!! Please help guys
86 Camaro
LG4, Tuned Q-Jet
Edlebrock Performer Intake, Edlebrock Open Element,High Flow Cat,Dynomax Catback,B&M Megashifter, 180* TSAT, 3.42s, 800 Watt System, !EGR
Old Jun 28, 2001 | 05:41 PM
Grand Prix's Avatar
Sounds like to me you need to simply ratchet it back down to drive and then the T will pull up. Once it does pull up shift it forward. I am certain those shifters lock out the T when you are in neutral. Probably to make it impossible to go to reverse from neutral. So in other words, nothing is broken its just not being used right. Don't feel bad, I have seen hundreds of people trip up on the ratchet shifters.
[This message has been edited by Grand Prix (edited June 28, 2001).]
Old Jun 28, 2001 | 09:11 PM
82camaro's Avatar
Car: 82 camaro SC
correct, the t-handle won't move in neutral. To move across the reverse lock-out you must be in OD and the t-handle pulled up.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jun 29, 2001 | 05:44 AM
Gta-Paladin's Avatar
Take off the shifter plate and have a look inside it's pretty straightforward.
How about banging it back down into od
or d or anything for that matter
Old Jun 29, 2001 | 07:42 AM
ok thanks guys,
Just called MAACO and they got it back into gear. I wonder if the heat had anything to do with it. The guy who drove it said that he burned his hand on the shifter putting into gear yesterday cause the car was in the sun. I appreciate the quick responses guys.
86 Camaro
LG4, Tuned Q-Jet
Old Jun 29, 2001 | 08:00 AM
irocbsa's Avatar
The entire shifter is made of metal. I seriously doubt that heat would have anything to do with it not shifting. I think the idiot just didn't know how to use it.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
F-body-fan
Jan 12, 2023 01:49 PM
tmellott89
Oct 14, 2015 02:06 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
