PCV hose, where to find a replacement?
Old Feb 13, 2005 | 01:27 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I am looking for the correct PCV hose that runs from the intake manifold to the drivers side valve cover on 89-92 5.7L TPI motors. I am running some regular hose and it is becoming soft and the oil seems to be penetrating it. Anyone know where I can find one. My stock piece had become all brittle and I was experiencing a little vacuum leak through there. Thanks fellas
Will
Old Feb 13, 2005 | 01:50 PM
Vader's Avatar
If you use Emission/EVAP rated hose, it should withstand the hot oil vapors. Perhaps you are using plain vacuum hose?
Old Feb 13, 2005 | 03:01 PM
norcalz28's Avatar
Where can I find Emissions hose?
Will
Old Feb 13, 2005 | 06:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your local parts store will have it cleverly disguised as "fuel hose".
Old Feb 14, 2005 | 07:51 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Even Fuel/PCV..
Old Feb 15, 2005 | 03:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
3/8 rubber fuel hose
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
mustangman65_79
Aug 8, 2015 12:07 PM
