I have an electric speedometer and a mechanical speedo tranny....HELP!
Old Jun 28, 2001 | 11:26 AM
crazeinc's Avatar
Please tell me exactly what I need in order for my electric speedometer to read the speed with my transmission that is setup for a mechanical speedo.
There's 2 issues here. One is that I really would like not to have to take apart the transmission and change those gears for my different rear-end gearing.
Is there setup to do adjustments with the speedometer just by adjusting a setting on a box or something?
1990 GTA
-355 carb'd, Richmond 4.10, Auburn posi, 1990 GTA
-355 carb'd, nicely reworked '67 vette heads, 2500 stall, 4.10's, other small things.
-Alston SFC's, Eibach Pro-kit, Koni's all around
-100+ nitrous shot
-Cruising in style with leather and nice stereo.
Old Jun 28, 2001 | 11:54 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Get the eletronic sending unit off of a transmission of the same year car that the eletronic dash came out of and wire it up using a scamatic from a repair manual, real simple.
Old Jun 28, 2001 | 12:03 PM
crazeinc's Avatar
well...I got the car with the electric speedometer but no tranny, so I put mine in...is this a cheap part I can order from GM and how is it installed?
Old Jun 29, 2001 | 03:12 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
It should be $100 or so, last I checked. And its simply a matter of taking out the mechanical VSS, and putting in your electronic VSS in its place. Just make sure you have the right driven gear on it.
Edit: This might help: http://www.sethirdgen.org/vss.htm
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited June 29, 2001).]
Old Jun 29, 2001 | 05:04 AM
Gta-Paladin's Avatar
This was in popular hot rodding June 2001 issue they swapped a 200-4r into a 4th Gen
"The 200-4R is set up to run a mechanical speedometer, while the fourth gen f-bodies are set up for electronic speedos. Yanks solution is to machine a stock t-56 speedo reluctor wheel to press-fit on the 200's output shaft they then drill a hole in the side of the transmission case weld on a suitable bung and inserted a stock t-56 speed sensor this is an elegant solution to a fundamental problem no wires to splice and a perfectly functioning speedometer every time, very nice!." now i do realize that the old tranny was a t-56 and granted the fact that i know nothing about cars i just read a lot of mags and am slowly trying to learn.. i wouldnt see the difference here.. someone correct me?
Old Jun 29, 2001 | 04:12 PM
crazeinc's Avatar
How do I just change over from the mechanical speedo housing on the tranny to the VSS setup??...I'll worry about screwing with those gears later, I just want a working speedometer and I'll figure out how much it's off!
Hotrodboba400
Dec 10, 2019 07:07 PM
TrevinE
Sep 14, 2015 03:20 PM
webeeZ28
Sep 14, 2015 12:00 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
