Can I edit CODE 32 out of my system?
Old Jun 29, 2001 | 02:26 PM
1990 IROCZ's Avatar
Well guys-
I've spend $400 trying to fix my EGR, and I still get an SES light when I get up to highway speeds...
The low-end bog has been fixed, and the car actually seems to run alot better and stronger with the new computer, so I guess I got something out of it.
I now want to look into getting Code 32 out of my computer system....I don't want to see that Service Engine Soon light on anymore..
Can someone tell me how to go about doing this? or if it's even possible?
Would there be any negative effects?
Is it possible just to disable the SES light altogether? like, maybe just unplug the damn thing?
Thanks guys
Year: 1990
Make: Chevorlet
Model: Z-28 / IROC-Z
Engine: 5.0L V8 TPI
Trans: 700R4 Auto w/ OD
Additional:'92 Z-28 Rims, T-Tops, Tinted Windows, Edelbrock Suspension Kit, Edelbrock Catback Exhaust (Chrome tips), K&N Air Filter
Old Jun 29, 2001 | 02:46 PM
94'_SS's Avatar
If you want to disable the light look in a hanyes or chiltion manual and find the wiring diagrams for output wire to the SES light from your computer and unplug it. On my S-10 it was a brown and white wire if that helps any.
Old Jun 29, 2001 | 03:36 PM
BGNCHRS's Avatar
Yes you can turn off the EGR code trip but you have to edit it out from your prom.
no other way around it.
Old Jun 29, 2001 | 05:01 PM
1990 IROCZ's Avatar
How do I "edit" it out of my PROM?
Again, will this cause any negative side effects?
Thanks~
Year: 1990
Make: Chevorlet
Engine: 5.0L V8 TPI
Old Jun 29, 2001 | 06:16 PM
Matt_91RSTPI's Avatar
Do you have headers on your car? If so, try a heated O2 sensor. This will correct for a code 32 being set when highway cruise speed has been stable for a certain amount of time but the O2 temp is still to low for the computer to go into open loop.
Otherwise, the simplest solution is probably to call Ed Wright at Fastchips and just get one of his. You can ask to have them remove the EGR function while you're at it.
Matt
Old Jun 29, 2001 | 09:17 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by 1990 IROCZ:
</font>
You would either have to order one from someone for at least 250 bucks... or you can spend a little less than that, get a burner, a program, a couple other parts, and burn your own chip.
92projectcamaro
Jan 18, 2016 08:00 AM
TBRays98
Sep 6, 2015 05:05 PM
Slush92RS
Sep 2, 2015 08:56 PM
RyanJB
Sep 2, 2015 01:27 PM
