Cam swap/ chip help needed
Old Feb 15, 2005 | 11:55 AM
68 RS/SS Ragtop's Avatar
Car: 68 RS/SS cnvrt, 92 Z28, 02Blkbrd
Engine: 295hp 350, 385hp 350, 420hp LS1
Transmission: 4spd, 700r4, T56
Axle/Gears: 3.11, 3.23, 3.42
A blown headgasket has given me the opportunity to do a few performance mods . My car is bone stock. I'd like to put headers on it.( I'm going with shortys and a new bolt on Y pipe), and since I 'm down to the block I thought I'd put a new cam and chip in. Nothing radical, (this car is supposed to be my daily driver). I don't plan on changing my TPI or throttlebody (52mm I think). I understand that if I change my cam a new stock hyper/superchip won't work. Can anyone recommend a cam/ chip package out there?
I'll be checking for response, but also welcome calls at 561 -523-9687 Thank you. Bob
Old Feb 15, 2005 | 02:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
Two forums on this Board are dedicated to your issue - TPI, and PROM. I'd recommend heading to them and see what's there.
One warning - select your cam carefully. If the manufacturer can't tell you that it absolutely works with a stock speed density TPI, don't get it.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
